Saltar al contenido principal
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
Qué necesitas
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: paso 1, imagen 1 de 1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: paso 2, imagen 1 de 1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: paso 3, imagen 1 de 1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: paso 4, imagen 1 de 1
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: paso 5, imagen 1 de 2 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: paso 5, imagen 2 de 2
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Conclusión
Una persona más ha completado esta guía.
Chino Cruz
Miembro Desde 01/22/18
135 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G4, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 54
Todo El Tiempo: 4,612
