Saltar al contenido principal
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
Qué necesitas
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: paso 1, imagen 1 de 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: paso 1, imagen 2 de 2
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: paso 2, imagen 1 de 1
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: paso 3, imagen 1 de 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: paso 3, imagen 2 de 2
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S11-G4, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Miembros
10 Guías creadas
Un comentario
Thank you, made it easy peasy!
J Colee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 30
Ultimos 30 días: 105
Todo El Tiempo: 8,632
