Saltar al contenido principal
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
Qué necesitas
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: paso 1, imagen 1 de 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: paso 1, imagen 2 de 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: paso 1, imagen 3 de 3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: paso 2, imagen 1 de 1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Conclusión
Equipo
Cal Poly, Team S11-G2, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Miembros
9 Guías creadas
3 comentarios
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Contestar
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 996
