Saltar al contenido principal
Hoover T-Series WindTunnel Pet UH30310 Brush Replacement
Qué necesitas
  1. Hoover T-Series WindTunnel Pet UH30310 Brush Replacement, Brush: paso 1, imagen 1 de 2 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement, Brush: paso 1, imagen 2 de 2
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 2, imagen 1 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 2, imagen 2 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 2, imagen 3 de 3
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
  3. Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 3, imagen 1 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 3, imagen 2 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
  4. Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 4, imagen 1 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 4, imagen 2 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 4, imagen 3 de 3
    • Remove the two screws on the left side of the brush.
  5. Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 5, imagen 1 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 5, imagen 2 de 3 Hoover T-Series WindTunnel Pet UH30310 Brush Replacement: paso 5, imagen 3 de 3
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
Conclusión
Erik Ingels
Miembro Desde 01/18/18
193 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S12-G4, Banghart Winter 2018 Miembro de Cal Poly, Team S12-G4, Banghart Winter 2018
CPSU-BANGHART-W18S12G4
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 349
