Introducción
This guide is for the Hoover Rogue 970 (Model BH70970) Smart Vacuum.
Is your Hoover Rogue 970 bumping into walls repeatedly? Is it wandering around aimlessly with no direction? This may be the fix for you! This is a guide to replace your vacuum's sensor!
Qué necesitas
Press the buttons on the brush roll cover inward.
Gently pull the brush roll cover away from the vacuum.
Locate the sensor.
Remove the four 12.5 mm screws with a Torx TR7 screwdriver.
Lift the sensor up and away from the device to access the white power cable connecting the sensor to the circuit board.
