Saltar al contenido principal
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
Qué necesitas
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: paso 1, imagen 1 de 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: paso 1, imagen 2 de 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: paso 1, imagen 3 de 3
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 2, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 2, imagen 2 de 2
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 3, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 3, imagen 2 de 2
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 4, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 4, imagen 2 de 2
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 5, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 5, imagen 2 de 2
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 6, imagen 1 de 1
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 7, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: paso 7, imagen 2 de 2
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
Conclusión
Una persona más ha completado esta guía.
katia zubieta
Miembro Desde 09/11/17
437 Reputación
4 Guías creadas
Equipo
CSU Fullerton, Team S2-G6, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G6, Bruce Fall 2017
CSUF-BRUCE-F17S2G6
3 Miembros
8 Guías creadas
4 comentarios
La pila dónde la puedo encontrar
alejandro rodriguez - Contestar
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - Contestar
Where does one buy the replacement battery?
mytikikitty - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 6,085
