Saltar al contenido principal
Hoover Presto 2-in-1 Cordless Stick Belt Replacement
Qué necesitas
  1. Hoover Presto 2-in-1 Cordless Stick Belt Replacement, Belt: paso 1, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Belt Replacement, Belt: paso 1, imagen 2 de 2
    • Press grey release button on stick vacuum to release vacuum head.
  2. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 2, imagen 1 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 2, imagen 2 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 2, imagen 3 de 3
    • Locate the circular black turn switch, which is in the upper right corner of the backside of the vacuum head
    • Using a metal spudger, place the tool in the indent of the circular turn switch and turn it from the left to the right or from the "locked" symbol to the "unlocked" symbol
  3. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 3, imagen 1 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 3, imagen 2 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 3, imagen 3 de 3
    • Flip the vacuum head over so that the wheels and screws are facing you.
    • Using a PH #1 screw driver, remove the four 15mm screws from each corner of the backside of the vacuum head.
  4. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 4, imagen 1 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 4, imagen 2 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 4, imagen 3 de 3
    • Locate the two wheels in the upper half of the vacuum head and remove them by sticking the metal spudger tool underneath the wheel and pushing it towards you until it pops out.
    • Remove the two 15mm screws located underneath the wheels with a PH #1 screw driver.
  5. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 5, imagen 1 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 5, imagen 2 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 5, imagen 3 de 3
    • Using a firm grip, pull the two halves of the vacuum head away from each other until they are completely separated
  6. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 6, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 6, imagen 2 de 2
    • Remove the mechanism with your hands.
  7. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 7, imagen 1 de 2 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 7, imagen 2 de 2
    • Remove the two 7mm screws located on either side of the roller with a PH #1 screw driver.
    • Removing these screws helps loosen the belt so that it is easier to take off the mechanism.
  8. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 8, imagen 1 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 8, imagen 2 de 3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: paso 8, imagen 3 de 3
    • Use a metal spudger to lift the belt away from the mechanism.
Conclusión
Una persona más ha completado esta guía.
katia zubieta
Miembro Desde 09/11/17
437 Reputación
4 Guías creadas
Equipo
CSU Fullerton, Team S2-G6, Bruce Fall 2017 Miembro de CSU Fullerton, Team S2-G6, Bruce Fall 2017
CSUF-BRUCE-F17S2G6
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 811
