Introducción
Brushes that clean using the solution/water. These brushes may need to be cleaned after usage and need to be detached in order to clean.
Qué necesitas
Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
With the vacuum laying on its back pull gently on the brush part and wiggle until it pulls out of place. Now the brushes are ready for cleaning.
