Saltar al contenido principal
Hoover LiNX The Nozzle Prongs Replacement
Qué necesitas
  1. Hoover LiNX The Nozzle Prongs Replacement, Replace The Motor: paso 1, imagen 1 de 1
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX The Nozzle Prongs Replacement: paso 2, imagen 1 de 1
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX The Nozzle Prongs Replacement: paso 3, imagen 1 de 2 Hoover LiNX The Nozzle Prongs Replacement: paso 3, imagen 2 de 2
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX The Nozzle Prongs Replacement: paso 4, imagen 1 de 1
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX The Nozzle Prongs Replacement: paso 5, imagen 1 de 1
    • Remove the bottom panel.
  6. Hoover LiNX The Nozzle Prongs Replacement: paso 6, imagen 1 de 1
    • Remove the motor.
  7. Hoover LiNX The Nozzle Prongs Replacement, The Nozzle Prongs: paso 7, imagen 1 de 1
    • Remove the two 7.5mm Phillips #1 screws from the main body.
  8. Hoover LiNX The Nozzle Prongs Replacement: paso 8, imagen 1 de 1
    • Remove the black covering from the air tube.
  9. Hoover LiNX The Nozzle Prongs Replacement: paso 9, imagen 1 de 1
    • Slide the prongs out through their channels.
  10. Hoover LiNX The Nozzle Prongs Replacement: paso 10, imagen 1 de 2 Hoover LiNX The Nozzle Prongs Replacement: paso 10, imagen 2 de 2
    • Remove the angled neck and feed the prongs out through their channels.
  11. Hoover LiNX The Nozzle Prongs Replacement: paso 11, imagen 1 de 2 Hoover LiNX The Nozzle Prongs Replacement: paso 11, imagen 2 de 2
    • Replace the prongs.
Conclusión
2 personas más completaron esta guía.
Sara Vlhova
Miembro Desde 01/25/18
541 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S7-G4, Passmore Spring 2018 Miembro de USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Miembros
12 Guías creadas
2 comentarios
How do I get to the receivers for the prongs? They appear to be too loose to make a connection and i have not been able to get into the body to tighten. Is there another way to improve this connection?
Robert L Worthing - Contestar
Thank you for asking ifixit your 11/1018 question. I’ve been trying to disassemble the body to get at the receiver(s)/socket(s) for those prongs for days. And ifixit, please, have you got a picture of the routing of the brush motor wires from the motor through the rolling assembly, the swiveling universal joint, and along the back of the airtube?
donwesel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 21
Ultimos 30 días: 40
Todo El Tiempo: 1,721
