Saltar al contenido principal
  1. 700 w cyclonic hoover 700 w cyclonic hoover
    • 700 w cyclonic hoover
  2. The active carbon filter is totally blocked. Air cannot flow !!! The active carbon filter is totally blocked. Air cannot flow !!! The active carbon filter is totally blocked. Air cannot flow !!!
    • The active carbon filter is totally blocked. Air cannot flow !!!
  3. Using a screwdriver and a cutter is almost simple to remove the filter. Using a screwdriver and a cutter is almost simple to remove the filter. Using a screwdriver and a cutter is almost simple to remove the filter.
    • Using a screwdriver and a cutter is almost simple to remove the filter.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Metal grid Foam Gauze
    • Metal grid
    • Foam
    • Gauze
  6. Cut the metal grid and place it. Place the gauze  (just a couple of sheets) over the grid.
    • Cut the metal grid and place it.
    • Place the gauze (just a couple of sheets) over the grid.
    • Cut and place the foam on top of the gauze.
  7. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  8. Insert wisdom here. Insert wisdom here. Insert wisdom here.
Conclusión
Una persona más ha completado esta guía.
Carlo Romagnoli
Miembro Desde 14/02/18
275 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 37
