Introducción
This guide will show you how to disassemble a Honeywell Turbo Force Air Circulator Fan, so cleaning the interior of the fan is easier. It will also allow for further actions to take place such as oiling the rotor of the fan.
Qué necesitas
Honeywell Turbo Force 12" Air Circulator.
Dimensions - 11.22" x 9.8" x 13.98", 5.7 lbs.
Remove the inside plastic ring around center shaft.
Enables the fan blades to be removed.
Use a flat head screwdriver to remove the plastic ring.
Remove the 2 screws on the motor.
This allows the motor to pull away from the housing.
Pull the motor away from the housing to expose wiring.
Remove the two screws from the back of the motor.
Allows the rotor and front/back bearings to be removed.
During reassembly, re-align the bearings by tapping on the shaft.
To reassemble the fan, follow these instructions in reverse order. Note that Step 12 is an extra step in the reassembly process to follow.
2 personas más completaron esta guía.
2 comentarios
I have a Honeywell HF910. I have taken the cover off but there are no screws behind the fan blades. Any suggestions on how to remove the fan blades? Thank you.
