Saltar al contenido principal
Honeywell HY-254-TGT Front Panel Replacement
Qué necesitas
  1. Honeywell HY-254-TGT Front Panel Replacement, Plastic Assembly: paso 1, imagen 1 de 1
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Front Panel Replacement: paso 2, imagen 1 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 2, imagen 2 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 2, imagen 3 de 3
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Front Panel Replacement: paso 3, imagen 1 de 1
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Front Panel Replacement: paso 4, imagen 1 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 4, imagen 2 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Front Panel Replacement, Front Panel: paso 5, imagen 1 de 2 Honeywell HY-254-TGT Front Panel Replacement, Front Panel: paso 5, imagen 2 de 2
    • Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
    • Lean the front panel forwards and set it down.
    • The front panel will not fully detach and cannot be removed. Do not try to forcibly remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Front Panel Replacement: paso 6, imagen 1 de 2 Honeywell HY-254-TGT Front Panel Replacement: paso 6, imagen 2 de 2
    • Gently lift and remove the panel covering the electronics assembly.
  7. Honeywell HY-254-TGT Front Panel Replacement: paso 7, imagen 1 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 7, imagen 2 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 7, imagen 3 de 3
    • Remove the four 1/2" Phillips #01 screws in the circuit board.
    • Gently pull the circuit board off of the rest of the front panel assembly.
  8. Honeywell HY-254-TGT Front Panel Replacement: paso 8, imagen 1 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 8, imagen 2 de 3 Honeywell HY-254-TGT Front Panel Replacement: paso 8, imagen 3 de 3
    • Lift out the internal part of the front panel to access the buttons.
  9. Honeywell HY-254-TGT Front Panel Replacement: paso 9, imagen 1 de 1
    • If necessary, remove the buttons by grabbing them with two fingers and pulling up and away from the panel.
    • Upon reassembly, ensure buttons are placed in the correct location.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 11-6, Forte Fall 2015 Miembro de Cal Poly, Team 11-6, Forte Fall 2015
CPSU-FORTE-F15S11G6
4 Miembros
4 Guías creadas
2 comentarios
the piece to make it turn is broken
clara rojas - Contestar
the piece that make it turn is broken!
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 5,533
