Saltar al contenido principal
Honeywell HY-254-TGT Fan Blade Replacement
Qué necesitas
  1. Honeywell HY-254-TGT Fan Blade Replacement, Plastic Assembly: paso 1, imagen 1 de 1
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Fan Blade Replacement: paso 2, imagen 1 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 2, imagen 2 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 2, imagen 3 de 3
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Fan Blade Replacement: paso 3, imagen 1 de 1
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Fan Blade Replacement: paso 4, imagen 1 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 4, imagen 2 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Fan Blade Replacement, Fan Blade: paso 5, imagen 1 de 2 Honeywell HY-254-TGT Fan Blade Replacement, Fan Blade: paso 5, imagen 2 de 2
    • Unscrew the two 1/2" Phillips #02 screws.
    • Upon doing so, the front panel of the fan can be leaned forward and set down.
    • The front panel is not detached from the body and cannot be completely removed. Do not try to forcefully remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Fan Blade Replacement: paso 6, imagen 1 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 6, imagen 2 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 6, imagen 3 de 3
    • Unscrew the two marked 1/2" Phillips #02 screws on the part holding the fan blade.
    • Slide the plastic fan cap off the fan while holding the fan blade to ensure it comes off smoothly.
  7. Honeywell HY-254-TGT Fan Blade Replacement: paso 7, imagen 1 de 2 Honeywell HY-254-TGT Fan Blade Replacement: paso 7, imagen 2 de 2
    • Remove the 1/4" Phillips #02 screw between the fan and the motor, located at the bottom of the fan.
    • You may need to rotate the fan blade to find the screw.
    • Upon reassembly, make sure that the notched part of the motor axle (blue square) lines up with the screw hole on the fan blade.
  8. Honeywell HY-254-TGT Fan Blade Replacement: paso 8, imagen 1 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 8, imagen 2 de 3 Honeywell HY-254-TGT Fan Blade Replacement: paso 8, imagen 3 de 3
    • Return back to the top of the fan blade. Lift the fan blade to a slight angle and gently pull it towards you.
    • If the fan blade seems stuck, spin the fan blade back and forth while pulling it towards you.
Conclusión
5 personas más completaron esta guía.
Mark Schefter
Miembro Desde 09/29/15
218 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-6, Forte Fall 2015 Miembro de Cal Poly, Team 11-6, Forte Fall 2015
CPSU-FORTE-F15S11G6
4 Miembros
4 Guías creadas
5 comentarios
Do you know where I can find the screw listed in step 7? I have seemed to misplaced it.
krayze1 - Contestar
Do you know the part number for the fan blade?
indiwench - Contestar
MARK: What is the part number of the long tall round fan blade cylinder filter, so I can order some? I am having GREAT difficulty finding this elusive part ANYWHERE on the good ol’ fashion internet. I have four of these Honeywell HY-254 fans in my home and they all need to have those cylinders replaced. These are GREAT fans, VERY, VERY QUIET and all new models by competitive companies are loud, rickety & poorly made. This version of honetwell, is by far, the BEST! I will stand by to hear from you. Thank you.
Anthony Ochoa - Contestar
my fan rotating but no air. After I cleaned the fan it functioned at level 3 only if I turn to level 2 or 1 the fan rotated but I don't feel any air come out from the fan. do you think the problem comes from the motor? do I have to change the motor?
Jamilah Azubir - Contestar
Thanks for the great repair guide!
I have a Honeywell HY-254E that looks exactly like the model in this guide. However, I have a problem with two of the screws. In my case the two middling screws that hold the backside of the main case and thatare above described as "3/4" Phillips #02 screws" look like Torx screws.
However, I don't have the right driver and I'm unsure which Torx size I need. Does anyone have an idea which Torx size this could be?
Many thanks in advance!
Chris
Christian Steinert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 20
Ultimos 30 días: 60
Todo El Tiempo: 10,358
