Saltar al contenido principal
Honeywell HY-204 Rotation Motor Replacement
Qué necesitas
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: paso 1, imagen 1 de 1
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: paso 2, imagen 1 de 1
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: paso 3, imagen 1 de 2 Honeywell HY-204 Rotation Motor Replacement: paso 3, imagen 2 de 2
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: paso 4, imagen 1 de 1
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: paso 5, imagen 1 de 1
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
Conclusión
Equipo
Cal Poly, Team 10-40, Amido Fall 2014 Miembro de Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
Miembros de 3
7 Guías creadas
2 comentarios
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 2,739
