Introducción
After repeated use, the supports that keep up the hood of a car’s trunk (trunk struts) can become weak. This can cause the trunk to close on users unless someone is manually holding it up. This guide shows how to replace these trunk struts on a 2019 Honda Civic.
Qué necesitas
Open the trunk and use an object like a pole or a broomstick to securely prop it open. You may prefer to have another person hold the trunk open while making the repair. Hazard: If not properly supported, the trunk may fall during the repair causing potential injury.
