Saltar al contenido principal
Homelite UT44172 Safety Switch Replacement
Qué necesitas
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: paso 1, imagen 1 de 1
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: paso 2, imagen 1 de 1
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: paso 3, imagen 1 de 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: paso 3, imagen 2 de 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: paso 3, imagen 3 de 3
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: paso 4, imagen 1 de 1
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
Conclusión
Daniel Endericavillacis
Miembro Desde 01/25/15
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 17-5, Watkins Winter 2015 Miembro de USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 333
