Saltar al contenido principal
Homedics UHE-CMP15 Water Replacement
Qué necesitas
  1. Homedics UHE-CMP15 Water Replacement, Water: paso 1, imagen 1 de 1
    • Unscrew the container from the lid.
    • Turn the cap counterclockwise and gently remove the lid from the container.
  2. Homedics UHE-CMP15 Water Replacement: paso 2, imagen 1 de 1
    • Remove the water that is already in the container and dump the old water into safe water disposal area.
    • Dump the old water outside or down the sink.
  3. Homedics UHE-CMP15 Water Replacement: paso 3, imagen 1 de 1
    • Clean out the container.
    • Use a towel, some soap, and water to clean out the container.
    • You can also use a mix of 50/50 white vinegar and water to clean.
    • Take the damp towel and move it along all off the container and then rinse it out with water.
  4. Homedics UHE-CMP15 Water Replacement: paso 4, imagen 1 de 1
    • Fill the container with fresh water.
    • Take some room temperature water from the sink and pour it into the clean container.
Conclusión
Dylan
Miembro Desde 10/30/23
337 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Konn Fall 2023 Miembro de UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 66
