Introducción
If the device is not charging, follow this guide to cleaning or replacing the charging cable. You will need a spudger and a spare type-c charging cable on hand.
Qué necesitas
Check the USB port/both ends of the charging cable for dust or grime buildup.
Casi Terminas!
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Conclusión
