Saltar al contenido principal
Homedics UHE-CMP15 Charging Cable Cleaning
Qué necesitas
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: paso 1, imagen 1 de 2 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: paso 1, imagen 2 de 2
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: paso 2, imagen 1 de 2 Homedics UHE-CMP15 Charging Cable Cleaning: paso 2, imagen 2 de 2
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: paso 3, imagen 1 de 1
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
Conclusión
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Kade Betterton
Miembro Desde 10/30/23
267 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Konn Fall 2023 Miembro de UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 66
