Saltar al contenido principal
Homedics UHE-CMP15 Battery Replacement
Qué necesitas
  1. Homedics UHE-CMP15 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure your device is turned off by pressing the power button and ensuring the LED lights are off.
    • Unscrew top from the container by twisting the top of the container counter clockwise and pulling up.
  2. Homedics UHE-CMP15 Battery Replacement: paso 2, imagen 1 de 1
    • Flip the top portion upside down and remove the wick and wick holder.
    • To remove the wick pull on the wick holder and it should pop right off.
  3. Homedics UHE-CMP15 Battery Replacement: paso 3, imagen 1 de 2 Homedics UHE-CMP15 Battery Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers and or the spudging tool lift 3 small white rubber caps, pry underneath them and pull to remove them.
    • This reveals the three screws holding the cap in place.
  4. Homedics UHE-CMP15 Battery Replacement: paso 4, imagen 1 de 1
    • Unscrew and remove the 3 screws with a Philips head screwdriver. The screwdriver must be very long and thin.
    • Tilting the device upside down will slide the unscrewed screws out from the holes they are in after they are loosened.
  5. Homedics UHE-CMP15 Battery Replacement: paso 5, imagen 1 de 3 Homedics UHE-CMP15 Battery Replacement: paso 5, imagen 2 de 3 Homedics UHE-CMP15 Battery Replacement: paso 5, imagen 3 de 3
    • The top portion will now be able to be removed to reveal the inside of the battery compartment.
    • The battery is glued to the side wall with an adhesive pad.
    • This battery is hardwired in, and will require skill in soldering/wiring and the ability to find a suitable replacement.
Conclusión
Kade Betterton
Miembro Desde 10/30/23
267 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Konn Fall 2023 Miembro de UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 104
