Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Herramientas
Partes
No se especificaron partes.
  1. Using a hair dryer on hot or a heat gun on low, carefully heat up the bottom foot for 1-2 minutes.
    • Using a hair dryer on hot or a heat gun on low, carefully heat up the bottom foot for 1-2 minutes.
  2. Using your fingernails or a guitar pick, separate the outer portion of the foot from the mesh and remove from the HomePod Be careful not to break the small tabs that position the foot to the bottom of the HomePod Be careful not to break the small tabs that position the foot to the bottom of the HomePod
    • Using your fingernails or a guitar pick, separate the outer portion of the foot from the mesh and remove from the HomePod
    • Be careful not to break the small tabs that position the foot to the bottom of the HomePod
Conclusión
Nicholas Ouimet
Miembro Desde 16/10/09
2,693 Reputación
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 51
