Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Holy Stone HS165 Drone Arm Gear Replacement
Qué necesitas
  1. Holy Stone HS165 Drone Arm Gear Replacement, Drone Arm Gear: paso 1, imagen 1 de 2 Holy Stone HS165 Drone Arm Gear Replacement, Drone Arm Gear: paso 1, imagen 2 de 2
    • Locate the defective drone arm on the drone.
    • You'll know if the gear needs to be replaced if you spin the propellers on the arm and feel a click when spinning.
  2. Holy Stone HS165 Drone Arm Gear Replacement: paso 2, imagen 1 de 2 Holy Stone HS165 Drone Arm Gear Replacement: paso 2, imagen 2 de 2
    • Remove the three 1.5 mm screws holding the propellers in place.
    • Pull out the propeller.
    • This can be done once you've removed the top of the drone which you'll be able to do once you've removed the screws.
  3. Holy Stone HS165 Drone Arm Gear Replacement: paso 3, imagen 1 de 1
    • Remove the small plastic cap that's under the propellers.
  4. Holy Stone HS165 Drone Arm Gear Replacement: paso 4, imagen 1 de 1
    • Be careful as this requires a lot of force and may send the cap flying in any direction
    • Remove the plastic cap that covers the gear with your hands but if needed, use a plastic spudger to support you.
  5. Holy Stone HS165 Drone Arm Gear Replacement: paso 5, imagen 1 de 1
    • Using plastic tweezers, pry off the gear from the drone.
  6. Holy Stone HS165 Drone Arm Gear Replacement: paso 6, imagen 1 de 2 Holy Stone HS165 Drone Arm Gear Replacement: paso 6, imagen 2 de 2
    • Using a caliper, measure the size of the gear.
  7. Holy Stone HS165 Drone Arm Gear Replacement: paso 7, imagen 1 de 1
    • Pull out the bag of plastic gears and find one that matches the original size.
    • To measure the size of the gears accurately, use your caliper again.
  8. Holy Stone HS165 Drone Arm Gear Replacement: paso 8, imagen 1 de 1
    • Place the gear in the previous spot.
    • Now reattach the plastic cap from the previous step and push the propellers back in.
    • Be sure to test out your drone's arm before reattaching everything to make sure it's working properly. Just push it up and down and back and forth.
    • To reassemble your drone, return to steps one and two.
Linea de Meta
Una persona más ha completado esta guía.
Colleen Denery
Miembro Desde 02/19/25
172 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-4, Andersen Winter 2025 Miembro de UC Davis, Team 2-4, Andersen Winter 2025
UCD-ANDERSEN-W25S2G4
Miembros de 3
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 44
Todo El Tiempo: 455
