Saltar al contenido principal
Holmes box fan motor replacement
Qué necesitas
  1. Holmes box fan motor replacement, Motor: paso 1, imagen 1 de 3 Holmes box fan motor replacement, Motor: paso 1, imagen 2 de 3 Holmes box fan motor replacement, Motor: paso 1, imagen 3 de 3
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
  2. Holmes box fan motor replacement: paso 2, imagen 1 de 2 Holmes box fan motor replacement: paso 2, imagen 2 de 2
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: paso 3, imagen 1 de 2 Holmes box fan motor replacement: paso 3, imagen 2 de 2
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: paso 4, imagen 1 de 1
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: paso 5, imagen 1 de 1
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: paso 6, imagen 1 de 3 Holmes box fan motor replacement: paso 6, imagen 2 de 3 Holmes box fan motor replacement: paso 6, imagen 3 de 3
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: paso 7, imagen 1 de 2 Holmes box fan motor replacement: paso 7, imagen 2 de 2
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: paso 8, imagen 1 de 1
    • Now you can insert your new motor and you are done!
Conclusión
6 personas más completaron esta guía.
Max Cossalter
Miembro Desde 09/29/15
341 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-4, Green Fall 2015 Miembro de Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 Miembros
4 Guías creadas
5 comentarios
Where might one find a replacement motor for a older box fan
Chris Cook - Contestar
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - Contestar
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - Contestar
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - Contestar
Also want to know where to find this kind of replacement motor?
Bridget Alice Alonso - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 12,998
