Saltar al contenido principal
Holmes HEH8031 Thermostat Replacement
Qué necesitas
  1. Holmes HEH8031 Thermostat Replacement, Housing: paso 1, imagen 1 de 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Thermostat Replacement: paso 2, imagen 1 de 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Thermostat Replacement: paso 3, imagen 1 de 2 Holmes HEH8031 Thermostat Replacement: paso 3, imagen 2 de 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Thermostat Replacement, Circuit Board Removal: paso 4, imagen 1 de 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Thermostat Replacement, Fan: paso 5, imagen 1 de 1
    • Remove two Phillips #2 12mm screws from housing
  6. Holmes HEH8031 Thermostat Replacement: paso 6, imagen 1 de 1
    • Remove zip tie from wire with pliers
  7. Holmes HEH8031 Thermostat Replacement: paso 7, imagen 1 de 1
    • Separate fan assembly from heating coil
  8. Holmes HEH8031 Thermostat Replacement, Thermostat: paso 8, imagen 1 de 1
    • Remove 1 Phillips #2 screw
  9. Holmes HEH8031 Thermostat Replacement: paso 9, imagen 1 de 1
    • Remove thermostat from rear housing
  10. Holmes HEH8031 Thermostat Replacement: paso 10, imagen 1 de 1
    • remove solder from thermostat wire on circuit board
    • Soldering iron will be hot
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 2-1, Baechle Fall 2016 Miembro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 1,278
