Saltar al contenido principal
Holmes HEH8031 Power Cord Replacement
Qué necesitas
  1. Holmes HEH8031 Power Cord Replacement, Housing: paso 1, imagen 1 de 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: paso 2, imagen 1 de 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: paso 3, imagen 1 de 2 Holmes HEH8031 Power Cord Replacement: paso 3, imagen 2 de 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: paso 4, imagen 1 de 3 Holmes HEH8031 Power Cord Replacement, Power Cord: paso 4, imagen 2 de 3 Holmes HEH8031 Power Cord Replacement, Power Cord: paso 4, imagen 3 de 3
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: paso 5, imagen 1 de 3 Holmes HEH8031 Power Cord Replacement: paso 5, imagen 2 de 3 Holmes HEH8031 Power Cord Replacement: paso 5, imagen 3 de 3
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: paso 6, imagen 1 de 2 Holmes HEH8031 Power Cord Replacement: paso 6, imagen 2 de 2
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
Conclusión
3 personas más completaron esta guía.
Deanna Jack
Miembro Desde 10/12/16
333 Reputación
4 Guías creadas
Equipo
IUPUI, Team 2-1, Baechle Fall 2016 Miembro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Miembros
16 Guías creadas
Un comentario
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,910
