Saltar al contenido principal
Holmes HEH8031 Control Buttons Replacement
Qué necesitas
  1. Holmes HEH8031 Control Buttons Replacement, Housing: paso 1, imagen 1 de 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: paso 2, imagen 1 de 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: paso 3, imagen 1 de 2 Holmes HEH8031 Control Buttons Replacement: paso 3, imagen 2 de 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: paso 4, imagen 1 de 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: paso 5, imagen 1 de 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: paso 5, imagen 2 de 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: paso 5, imagen 3 de 3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: paso 6, imagen 1 de 3 Holmes HEH8031 Control Buttons Replacement: paso 6, imagen 2 de 3 Holmes HEH8031 Control Buttons Replacement: paso 6, imagen 3 de 3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
Conclusión
Una persona más ha completado esta guía.
Chris Shaffer
Miembro Desde 10/12/16
255 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-1, Baechle Fall 2016 Miembro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 464
