Saltar al contenido principal
Holmes HEH8031 Circuit Board Replacement
Qué necesitas
  1. Holmes HEH8031 Circuit Board Replacement, Housing: paso 1, imagen 1 de 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Circuit Board Replacement: paso 2, imagen 1 de 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Circuit Board Replacement: paso 3, imagen 1 de 2 Holmes HEH8031 Circuit Board Replacement: paso 3, imagen 2 de 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Circuit Board Replacement, Circuit Board Removal: paso 4, imagen 1 de 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Circuit Board Replacement, Circuit Board: paso 5, imagen 1 de 3 Holmes HEH8031 Circuit Board Replacement, Circuit Board: paso 5, imagen 2 de 3 Holmes HEH8031 Circuit Board Replacement, Circuit Board: paso 5, imagen 3 de 3
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Circuit Board Replacement: paso 6, imagen 1 de 2 Holmes HEH8031 Circuit Board Replacement: paso 6, imagen 2 de 2
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
Conclusión
Una persona más ha completado esta guía.
Chris Shaffer
Miembro Desde 10/12/16
255 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-1, Baechle Fall 2016 Miembro de IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
Miembros de 4
16 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,030
