Saltar al contenido principal
Hollowtech Bottom Bracket Replacement
Qué necesitas
  1. Hollowtech Bottom Bracket Replacement, Bottom Bracket: paso 1, imagen 1 de 1
    • Secure the bicycle using a bicycle repair stand or wall.
  2. Hollowtech Bottom Bracket Replacement: paso 2, imagen 1 de 2 Hollowtech Bottom Bracket Replacement: paso 2, imagen 2 de 2
    • Use pliers to remove the spring clip from the chain's master link clip.
    • Remove the master link plate, plate and pin assembly, and finally the chain.
  3. Hollowtech Bottom Bracket Replacement: paso 3, imagen 1 de 3 Hollowtech Bottom Bracket Replacement: paso 3, imagen 2 de 3 Hollowtech Bottom Bracket Replacement: paso 3, imagen 3 de 3
    • Use a 10mm Allen key socket and ratchet to loosen the left crank arm by twisting counter clockwise.
    • Remove the left crank arm.
    • Remove the spacer(s) and washer.
  4. Hollowtech Bottom Bracket Replacement: paso 4, imagen 1 de 3 Hollowtech Bottom Bracket Replacement: paso 4, imagen 2 de 3 Hollowtech Bottom Bracket Replacement: paso 4, imagen 3 de 3
    • Either push or pull the crank arm fully out exposing the left bottom bracket.
  5. Hollowtech Bottom Bracket Replacement: paso 5, imagen 1 de 2 Hollowtech Bottom Bracket Replacement: paso 5, imagen 2 de 2
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the left bottom bracket by twisting counter clockwise.
    • Remove the bottom bracket.
  6. Hollowtech Bottom Bracket Replacement: paso 6, imagen 1 de 2 Hollowtech Bottom Bracket Replacement: paso 6, imagen 2 de 2
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the right bottom bracket by twisting counter clockwise.
  7. Hollowtech Bottom Bracket Replacement: paso 7, imagen 1 de 3 Hollowtech Bottom Bracket Replacement: paso 7, imagen 2 de 3 Hollowtech Bottom Bracket Replacement: paso 7, imagen 3 de 3
    • Carefully pull out the bottom bracket shell.
Conclusión
Congratulations, you have completed the guide. To reassemble the crankset, follow these instructions in reverse order. Make sure to grease the threads, bottom bracket shell, and crankset accordingly. In addition, torque down the crank arm (38-41Nm) and bottom bracket (40-50Nm) to the manufacturer's recommended specification.
Agustin Sernas
Miembro Desde 10/23/23
145 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 13-3, Ribeiro Fall 2023 Miembro de CSU Los Angeles, Team 13-3, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S13G3
Miembros de 3
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 29
Todo El Tiempo: 278
