Introducción
If your humidifier seems to not be turning on, follow this guide to access the power supply board. This guide is an easy-to-follow process of how to remove your power supply board for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace your power supply board.
Qué necesitas
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Casi Terminas!
Conclusión
