Saltar al contenido principal
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
Qué necesitas
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: paso 1, imagen 1 de 1
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: paso 2, imagen 1 de 1
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: paso 3, imagen 1 de 1
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
Conclusión
Mike
Miembro Desde 01/25/17
397 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-2, Banghart Winter 2017 Miembro de Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Miembros
7 Guías creadas
Un comentario
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 426
