Saltar al contenido principal
Hisense Sero 8 Motherboard Replacement
Qué necesitas
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Hisense Sero 8 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Hisense Sero 8 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: paso 2, imagen 1 de 2 Hisense Sero 8 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: paso 4, imagen 1 de 1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: paso 5, imagen 1 de 3 Hisense Sero 8 Motherboard Replacement: paso 5, imagen 2 de 3 Hisense Sero 8 Motherboard Replacement: paso 5, imagen 3 de 3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Conclusión
Katharina
Miembro Desde 02/23/15
506 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-2, Leahy Winter 2015 Miembro de USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,303
