Saltar al contenido principal
Hisense Sero 7 Pro Battery Replacement
Qué necesitas
  1. Hisense Sero 7 Pro Battery Replacement, Battery: paso 1, imagen 1 de 2 Hisense Sero 7 Pro Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Battery Replacement: paso 2, imagen 1 de 2 Hisense Sero 7 Pro Battery Replacement: paso 2, imagen 2 de 2
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Battery Replacement: paso 3, imagen 1 de 2 Hisense Sero 7 Pro Battery Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
Conclusión
Baochau Nguyen
Miembro Desde 10/11/16
314 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 38-2, Bennett Fall 2016 Miembro de Texas Tech, Team 38-2, Bennett Fall 2016
TTU-BENNETT-F16S38G2
Miembros de 4
6 Guías creadas
2 comentarios
would be nice to actually have replacement battery avaible to buy new battery
howlingwolff10 - Contestar
Where could one buy new battery?
Joshua Wood - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 2,750
