Saltar al contenido principal
  1. Make sure that the laptop is turned off and disconnected from any power sources.
    • Make sure that the laptop is turned off and disconnected from any power sources.
    • Flip over the Chromebook.
    • Unscrew the screws with PH11 screwdriver.
  2. Remove the front two hub caps.
    • Remove the front two hub caps.
  3. Unscrew the screws with PH11 screwdriver.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Pry the perimeter of the case with a  plastic opening tool.
    • Pry the perimeter of the case with a plastic opening tool.
    • Remove the back panel.
  6. Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with a PH000 screwdriver.
  7. Use tweezers to unplug the battery.
    • Use tweezers to unplug the battery.
  8. Remove the battery.
    • Remove the battery.
Conclusión
Alexander Burrell
Miembro Desde 09/10/18
355 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G3, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 18
Últimos 30 Días: 87
Todo El Tiempo: 502
