Introducción
This screen replacement guide will walk you through the steps on how to replace a broken or cracked screen for a Hipstreet Titan Plus. This device will require you to work with small electronic components, so use care not to damage parts. Use an area that is clean and clear of debris and make sure that you have the proper tools for replacement before taking apart your device.
Qué necesitas
Use the iFixit opening tools to pry the screen from the back casing of the device.
Now that the screen and back casing have been separated, lay them flat on the table with the inside facing up.
2 personas más completaron esta guía.
