Saltar al contenido principal
Hipstreet Titan Plus Screen Replacement
Qué necesitas
  1. Hipstreet Titan Plus Screen Replacement, Screen: paso 1, imagen 1 de 2 Hipstreet Titan Plus Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Use the iFixit opening tools to pry the screen from the back casing of the device.
    • Now that the screen and back casing have been separated, lay them flat on the table with the inside facing up.
  2. Hipstreet Titan Plus Screen Replacement: paso 2, imagen 1 de 1
    • Use the spudger tool to remove the speaker from back casing of the device.
  3. Hipstreet Titan Plus Screen Replacement: paso 3, imagen 1 de 1
    • Use the tweezers to remove the black adhesive strips covering the wires.
    • After, set the strips aside. You will use them later.
  4. Hipstreet Titan Plus Screen Replacement: paso 4, imagen 1 de 2 Hipstreet Titan Plus Screen Replacement: paso 4, imagen 2 de 2
    • Use the spudger to release the three black clips.
    • Ensure to remove the main far right clip, which connects the screen to the motherboard.
  5. Hipstreet Titan Plus Screen Replacement: paso 5, imagen 1 de 2 Hipstreet Titan Plus Screen Replacement: paso 5, imagen 2 de 2
    • Remove the three screws from the bottom of the motherboard.
  6. Hipstreet Titan Plus Screen Replacement: paso 6, imagen 1 de 2 Hipstreet Titan Plus Screen Replacement: paso 6, imagen 2 de 2
    • Use a spudger to gently remove the battery from the motherboard.
  7. Hipstreet Titan Plus Screen Replacement: paso 7, imagen 1 de 1
    • All components will be removable from the screen after the battery, motherboard and all the black clips have been undone.
  8. Hipstreet Titan Plus Screen Replacement: paso 8, imagen 1 de 2 Hipstreet Titan Plus Screen Replacement: paso 8, imagen 2 de 2
    • Use the spudger to push back the clips along the side of the device and remove the screen.
Conclusión
2 personas más completaron esta guía.
Kari Cannon
Miembro Desde 10/30/15
500 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-1, Miles Fall 2015
UMASSD-MILES-F15S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 522
