Saltar al contenido principal
Hipstreet Equinox 2 Speaker Replacement
Qué necesitas
  1. Hipstreet Equinox 2 Speaker Replacement, Rear Case: paso 1, imagen 1 de 1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Speaker Replacement: paso 2, imagen 1 de 1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Use a plastic opening tool to remove the speakers from the case.
    • Desolder the wires from the motherboard.
    • Be sure to note which wire, red or black, corresponds to which connection on the motherboard.
  4. Hipstreet Equinox 2 Speaker Replacement: paso 4, imagen 1 de 1
    • Solder the wires of the new speaker to the motherboard as shown in the image.
  5. Hipstreet Equinox 2 Speaker Replacement: paso 5, imagen 1 de 1
    • Glue the speakers flat against their respective sound output panels with the silver sides facing out/towards the interior of the tablet.
Conclusión
Una persona más ha completado esta guía.
Joel Miller
Miembro Desde 01/29/15
119 Reputación
1 Guía escrita
Equipo
Clemson, Team 15-8, Shirley Winter 2015 Miembro de Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 200
