Saltar al contenido principal
Hipstreet Equinox 2 Motherboard Replacement
Qué necesitas
  1. Hipstreet Equinox 2 Motherboard Replacement, Rear Case: paso 1, imagen 1 de 1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
  4. Hipstreet Equinox 2 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
  5. Hipstreet Equinox 2 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
  6. Hipstreet Equinox 2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
Conclusión
Equipo
Clemson, Team 15-8, Shirley Winter 2015 Miembro de Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 357
