Saltar al contenido principal
Hipstreet Equinox 2 Battery Replacement
Qué necesitas
  1. Hipstreet Equinox 2 Battery Replacement, Rear Case: paso 1, imagen 1 de 1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Battery Replacement: paso 2, imagen 1 de 1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Disconnect the wires that connect the battery to the motherboard using the spudger.
  4. Hipstreet Equinox 2 Battery Replacement: paso 4, imagen 1 de 1
    • Slide the spudger underneath the battery and gently lift it off of the adhesive.
  5. Hipstreet Equinox 2 Battery Replacement: paso 5, imagen 1 de 2 Hipstreet Equinox 2 Battery Replacement: paso 5, imagen 2 de 2
    • Place the new battery in the same location and connect the wires the same way as the previous battery.
Conclusión
Equipo
Clemson, Team 15-8, Shirley Winter 2015 Miembro de Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 8
Todo El Tiempo: 769
