Introducción
The following will accurately show how to access the motherboard inside of the earbud charging case if it is in need of replacement due to damage from a possible collision or dropping of the case.
Qué necesitas
Use a spudger or other prying tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
Casi Terminas!
Conclusión
