Saltar al contenido principal
Heyday Round Bluetooth Speaker Disassembly
Qué necesitas
  1. Heyday Round Bluetooth Speaker Disassembly, Heyday Round Bluetooth Speaker Disassembly: paso 1, imagen 1 de 2 Heyday Round Bluetooth Speaker Disassembly, Heyday Round Bluetooth Speaker Disassembly: paso 1, imagen 2 de 2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Disassembly: paso 2, imagen 1 de 3 Heyday Round Bluetooth Speaker Disassembly: paso 2, imagen 2 de 3 Heyday Round Bluetooth Speaker Disassembly: paso 2, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
Conclusión
Hunter Brown
Miembro Desde 09/22/22
185 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 684
