Saltar al contenido principal
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement
Qué necesitas
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: paso 1, imagen 1 de 2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: paso 1, imagen 2 de 2
    • Bend the headset so that you can see the 1.2mm screws that need to be removed before removing the hinge. Next, take a hold of a Philips screwdriver size 00 and remove the screws.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement: paso 2, imagen 1 de 1
    • After removing the two screws, you can replace the hinge by removing it from the wire.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 78
