Saltar al contenido principal
Heel Tip Replacement
Qué necesitas
  1. Heel Tip Replacement, Heel Tip: paso 1, imagen 1 de 1
    • Measure the size of your heel tips to know what size to purchase.
    • Most sizes are in the range of 8-13 mm. The variety packs are handy, especially if you have a few pairs to fix.
    • The size pictured in this fix is a 12mm heel tip on a size 9 heel.
  2. Heel Tip Replacement: paso 2, imagen 1 de 1
    • Wedge a dull picket knife or jimmy between the top of the heel tip to help loosen and separate the tip.
  3. Heel Tip Replacement: paso 3, imagen 1 de 2 Heel Tip Replacement: paso 3, imagen 2 de 2
    • Carefully remove the heel tip with the pliers by twisting and pulling it out. Most can be turned counter clockwise to remove. Be careful not to pull only the rubber off.
  4. Heel Tip Replacement: paso 4, imagen 1 de 2 Heel Tip Replacement: paso 4, imagen 2 de 2
    • Clean the newly exposed tip of any debris.
  5. Heel Tip Replacement: paso 5, imagen 1 de 1
    • Place the pin end of the new tip into the heels opening.
  6. Heel Tip Replacement: paso 6, imagen 1 de 2 Heel Tip Replacement: paso 6, imagen 2 de 2
    • Gently tap the new tip in with the hammer. Careful not to damage the shoes material.
  7. Heel Tip Replacement: paso 7, imagen 1 de 2 Heel Tip Replacement: paso 7, imagen 2 de 2
    • Adjust the tip with the pliers to align the heel tip.
Conclusión
13 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 162
Ultimos 30 días: 713
Todo El Tiempo: 84,438
