1. First look around the edges of the LED display to see if there are broken or missing solder connections with the circuit board. If any are seen then it may be as simple as re-soldering the display to the board. Otherwise the LED display likely needs to be replaced if there are display issues.
    • First look around the edges of the LED display to see if there are broken or missing solder connections with the circuit board. If any are seen then it may be as simple as re-soldering the display to the board. Otherwise the LED display likely needs to be replaced if there are display issues.
  2. Take a soldering iron and separate each of the connections between the circuit board and LED display. Once all of the connections are removed, pull away the broken LED display.
    • Take a soldering iron and separate each of the connections between the circuit board and LED display. Once all of the connections are removed, pull away the broken LED display.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    • Remove unnecessary solder left over from the old connections to make sure each connection is separate while leaving a small amount on the board itself so it’s easier to make new connections.
  4. Use the soldering iron and solder to make connections between the new LED display and the circuit board. Be sure to not let any of the connections touch, otherwise the display will not function correctly.
    • Use the soldering iron and solder to make connections between the new LED display and the circuit board. Be sure to not let any of the connections touch, otherwise the display will not function correctly.
  5. Test the LED display. If there are still errors in the display then check your connections. If no issues are seen then it may be the circuit board itself, see Circuit Board Replacement.
    • Test the LED display. If there are still errors in the display then check your connections. If no issues are seen then it may be the circuit board itself, see Circuit Board Replacement.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 31
