Saltar al contenido principal
Health o Meter HDR743 Power Supply Replacement
Qué necesitas
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: paso 1, imagen 1 de 1
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: paso 2, imagen 1 de 1
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: paso 3, imagen 1 de 1
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: paso 4, imagen 1 de 2 Health o Meter HDR743  Power Supply Replacement: paso 4, imagen 2 de 2
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 126
