Saltar al contenido principal
Headphone Jack
Qué necesitas
  1. Headphone Jack, Battery: paso 1, imagen 1 de 1
    • Unplug laptop from adapter and all other devices.
  2. Headphone Jack: paso 2, imagen 1 de 1
    • Flip the laptop over with battery facing you.
  3. Headphone Jack: paso 3, imagen 1 de 2 Headphone Jack: paso 3, imagen 2 de 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Headphone Jack: paso 4, imagen 1 de 1
    • Pull battery out.
  5. Headphone Jack, Keyboard: paso 5, imagen 1 de 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Headphone Jack: paso 6, imagen 1 de 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. Headphone Jack: paso 7, imagen 1 de 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. Headphone Jack: paso 8, imagen 1 de 1
    • Remove keyboard wire by popping latch under blue plastic
  9. Headphone Jack, Case: paso 9, imagen 1 de 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. Headphone Jack: paso 10, imagen 1 de 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. Headphone Jack: paso 11, imagen 1 de 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. Headphone Jack: paso 12, imagen 1 de 3 Headphone Jack: paso 12, imagen 2 de 3 Headphone Jack: paso 12, imagen 3 de 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. Headphone Jack, Headphone Jack: paso 13, imagen 1 de 1
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  14. Headphone Jack: paso 14, imagen 1 de 1
    • Use plastic pry tool to lift up on headphone jack assembly
Conclusión
Tyler Lirio
Miembro Desde 02/13/18
93 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S11-G2, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 205
