Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Remove and replace a headlight bulb on the third-generation Dodge Ram 1500.
Partes
No se especificaron partes.
  1. Open the hood by pulling the hood lever in the driver-side footwell. Reach under the center of the grille and press the hood latch. Reach under the center of the grille and press the hood latch.
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly. Unscrew the second screw located approximately 6 inches below the first. Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  5. Approach this step with the process of unbuttoning a shirt in mind. Be careful if the rubber gasket is dry-rotted.  Use vaseline to re-moisturize if necessary.  Manipulating dry-rotted rubber will result in tearing.
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
  6. Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off. Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
  7. Rotate the outer ring of the headlight bulb holder counterclockwise to remove it. Carefully pull the headlight bulb holder out of its socket.
    • Rotate the outer ring of the headlight bulb holder counterclockwise to remove it.
    • Carefully pull the headlight bulb holder out of its socket.
    • When installing a headlight bulb, do not touch the bulb with your bare skin. Wear gloves when installing a new headlight bulb. Halogen bulbs are sensitive to skin oils, and the bulb may burn out quickly if you touch the bulb during installation.
    • If you accidentally touch the bulb, clean it immediately using rubbing alcohol on a clean cloth.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 3-24, Amido Fall 2012 Miembro de Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 Miembros
8 Guías creadas
What is that rubber gasket called or a part # please, mine is all torn from previous owner
diggemsmacks2000 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 37
Todo El Tiempo: 8,479
