Saltar al contenido principal
Hasbro furby 2012 Light Sensor Replacement
Qué necesitas
  1. Hasbro furby 2012 Light Sensor Replacement, Outer Shell: paso 1, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement, Outer Shell: paso 1, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement, Outer Shell: paso 1, imagen 3 de 3
    • Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
  2. Hasbro furby 2012 Light Sensor Replacement: paso 2, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 2, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #0 driver to unscrew the eight 10mm screws.
    • Remove the base ring after unscrewing all the screws.
    • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
  3. Hasbro furby 2012 Light Sensor Replacement: paso 3, imagen 1 de 2 Hasbro furby 2012 Light Sensor Replacement: paso 3, imagen 2 de 2
    • Unhook the white ribbon from the tab on the base.
  4. Hasbro furby 2012 Light Sensor Replacement: paso 4, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 4, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 4, imagen 3 de 3
    • Roll the Furby's fur downward.
    • Disconnect the now exposed red wire.
  5. Hasbro furby 2012 Light Sensor Replacement: paso 5, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 5, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 5, imagen 3 de 3
    • Locate the two middle clips first.
    • Locate the two remaining clips on Furby's sides, they are opposite each other.
    • Orient the Furby upside down with the tail facing away from you.
  6. Hasbro furby 2012 Light Sensor Replacement: paso 6, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 6, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 6, imagen 3 de 3
    • Insert a metal prying tool directly into the clip opening.
    • Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
    • Repeat the previous step to remove the remaining three clips.
  7. Hasbro furby 2012 Light Sensor Replacement: paso 7, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 7, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 7, imagen 3 de 3
    • Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
    • Lift up on the fur covering until the face of the Furby is exposed.
  8. Hasbro furby 2012 Light Sensor Replacement: paso 8, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 8, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement: paso 8, imagen 3 de 3
    • Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
    • Lift tape gently and peel back until the tape is nearly removed.
    • Do not pull on the yellow wire located on the opposite end of the tape.
  9. Hasbro furby 2012 Light Sensor Replacement: paso 9, imagen 1 de 2 Hasbro furby 2012 Light Sensor Replacement: paso 9, imagen 2 de 2
    • Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
    • Remove the 10mm screws with the Phillips#0 screwdriver.
  10. Hasbro furby 2012 Light Sensor Replacement: paso 10, imagen 1 de 1
    • Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
    • Peel the tape up until it is nearly detached from the black case.
  11. Hasbro furby 2012 Light Sensor Replacement: paso 11, imagen 1 de 2 Hasbro furby 2012 Light Sensor Replacement: paso 11, imagen 2 de 2
    • Orient the Furby face down, with the base facing away from you.
    • Locate the clips below the ears.
    • Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
  12. Hasbro furby 2012 Light Sensor Replacement: paso 12, imagen 1 de 2 Hasbro furby 2012 Light Sensor Replacement: paso 12, imagen 2 de 2
    • Remove the loose, plastic back panel by pulling the panel away from Furby's body.
  13. Hasbro furby 2012 Light Sensor Replacement, Light Sensor: paso 13, imagen 1 de 3 Hasbro furby 2012 Light Sensor Replacement, Light Sensor: paso 13, imagen 2 de 3 Hasbro furby 2012 Light Sensor Replacement, Light Sensor: paso 13, imagen 3 de 3
    • Remove the 10mm Phillips #0 screw holding the circuit board in.
    • Gently lift out the circuit board.
  14. Hasbro furby 2012 Light Sensor Replacement: paso 14, imagen 1 de 2 Hasbro furby 2012 Light Sensor Replacement: paso 14, imagen 2 de 2
    • Orient the Furby with the tail pointing left and the face pointing right.
    • Use the pointed tweezers to spread open the socket, and the blunt tweezers to grip and tug out the connector.
    • Insert your replacement light sensor connector.
Conclusión
Equipo
Cal Poly, Team 15-5, Livingston Fall 2016 Miembro de Cal Poly, Team 15-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,042
