Introducción
This guide will show you how to replace the switch required for the back panel to be removed. The hardest part of this guide is removing the clips holding the fur on the back panel in place.
Qué necesitas
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Locate and remove the two screws holding in the switch using J0 Phillips Head Screw Driver.
Casi Terminas!
Conclusión
