Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If the game is turned on but the Bop-It button(s) does not work, this is because the button inside the device that provides functionality may be broken. To effectively replace them see this step-by-step guide.
Partes
No se especificaron partes.
  1. Using a #0 phillips screwdriver, remove the (2) #4 Phillips head 8mm screws holding the  back cover on. Note that the screws are captured in the back cover, so they do not need to be completely removed.
    • Using a #0 phillips screwdriver, remove the (2) #4 Phillips head 8mm screws holding the back cover on. Note that the screws are captured in the back cover, so they do not need to be completely removed.
  2. Remove the (6) #3 Phillips head 6 mm screws shown in any order, also using the #0 phillips screwdriver.  When removing the final screw, hold the assembly together.  There is a spring inside the device which will pop the assembly apart when all the screws are removed.
    • Remove the (6) #3 Phillips head 6 mm screws shown in any order, also using the #0 phillips screwdriver. When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. Carefully separate the two sections, leaving them connected by the wires.  At this point, your device should look like this.  This completes the teardown.
    • Carefully separate the two sections, leaving them connected by the wires. At this point, your device should look like this. This completes the teardown.
  5. Remove the buttons by de-soldering them from the wires they are attached to or from the mother board.  Refer to the soldering guide here.
    • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
  6. After removing the buttons, solder new, operational buttons back into place.
    • After removing the buttons, solder new, operational buttons back into place.
Conclusión
3 personas más completaron esta guía.
Glenn Haag
Miembro Desde 29/09/16
479 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-1, Harley Fall 2016 Miembro de IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,020
