Saltar al contenido principal
Harman Kardon Onyx Studio 2 Speakers Replacement
Qué necesitas
  1. Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: paso 1, imagen 1 de 3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: paso 1, imagen 2 de 3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: paso 1, imagen 3 de 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 2, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 3, imagen 1 de 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 4, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement: paso 4, imagen 2 de 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Speakers Replacement, Control Board: paso 5, imagen 1 de 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 6, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement: paso 6, imagen 2 de 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 7, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement: paso 7, imagen 2 de 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: paso 8, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: paso 8, imagen 2 de 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 9, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement: paso 9, imagen 2 de 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
  10. Harman Kardon Onyx Studio 2 Speakers Replacement, Speakers: paso 10, imagen 1 de 1
    • Using the metal spudger, gently pry off the two red and black connectors.
  11. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 11, imagen 1 de 2 Harman Kardon Onyx Studio 2 Speakers Replacement: paso 11, imagen 2 de 2
    • Remove the four 14.3 mm T10 Torx screws.
  12. Harman Kardon Onyx Studio 2 Speakers Replacement: paso 12, imagen 1 de 1
    • Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
Conclusión
7 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-5, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Miembros
24 Guías creadas
2 comentarios
Hi, do anyone know sparepart number for woofer elements?
Mikko Lehto - Contestar
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
James Santiago - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 23
Ultimos 30 días: 83
Todo El Tiempo: 19,518
